Washing Machines Logo
A
Anonymous Posted on Jan 19, 2014
What is error code 66 on a fisher & paykel IW12 top load washer
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Apr 21, 2018
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314510
Points
1478
This is a faulty transducer which is located on the main board unfortunatley you will need to replace the whole thing
5 Related Answers
Lollo Pop
  • 134 Answers
  • Posted on Jul 10, 2009
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Anonymous
  • 10 Answers
  • Posted on Aug 03, 2009
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Apr 28, 2010
SOURCE: Fisher and Paykel GWL11 Top Load Washer won't
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
neil
  • 30 Answers
  • Posted on Jun 08, 2010
SOURCE: Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
luisa_sgro
  • 713 Answers
  • Posted on Oct 08, 2010
SOURCE: how do I take apart my fisher & paykel top
Hi just read your posting.Now if you look under the machine to the front right you will see a fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely.Put the machine back on its feet and select a spin cycle and push the start button.The machine should start to drain.Please reply on how you got on or if the machine still does not drain or for further assistance.Looking forward to your reply.
Fisher & Paykel GWL11 top loader. Fault code 136. How to fix the problem, the washer won't spin or drain.
Question edited for clarity, turn question around, add CAPS.
It is a motor stall. You need a technician.
Washing Machine - Top Loader Fault Code Numbers
Fisher & Paykel https://support.fisherpaykel.com > article > Washing-M... Sep 30, 2023 - 136, Motor Error - You will need a Service Technician to assist with this - Click Here to ... © Fisher & Paykel Appliances Ltd 2023. Loading.
Questions & Answers for: fisher paykel fault code 136
Fixya https://www.fixya.com > ... > fisher paykel fault code 136 Now Error code 136 means you have a motor stall ... Question about GWL11 Top Load Washer. 1 Answer · What is fault code 136 on fisher & paykel ...
I have a fisher paykel GWL11 that will fill and drain but
JustAnswer https://www.justanswer.com > Appliance Repair May 25, 2017 - If you had a 130 and a 136, the sensor is not likely the issue. Will the tub turn manually? How about lift up and down? Ask Your Own Appliance ...
1 answer · Top answer: Oh, that plastic nut will come off. See the link below. CLICK HERE
https://www.google.com/search?q=Fisher+%26+Paykel+GWL11+top+loader.+Fault+code+136
Fisher and Paykel top load washer, code 66 ?
this normally a transducer fault in your main board,board will need replacing
1helpful
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Error code 3
Error code 3
Your motor controller module is faulty.
Has a memory error & needs replacing.
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
2helpful
4helpful
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
7helpful
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
1helpful
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
