Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
A
Anonymous Posted on May 16, 2017
Top drawer power shut off and the lock icon appeared in the unlit window. I held down the lock button and the power came back on. Then while running, the unit stopped running and F2 began flashing (with a wrench logo) in the darkened window. We have removed the water from the drawer and removed and cleaned the impeller. Reassembled everything and ran the cycle. Seems to work fine now. We did discover a very small piece of bone in the impeller and once removed, seemed to function OK.
5 Related Answers
Anonymous
  • 461 Answers
  • Posted on Sep 09, 2007
SOURCE: no power top drawer
Try to reset your dish washer. Turn off main power supply and leave it for at least 1 min. Is there any error code appear/beeping sound?
Anonymous
  • 62 Answers
  • Posted on Feb 13, 2008
SOURCE: dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Anonymous
  • 351 Answers
  • Posted on Mar 03, 2008
SOURCE: Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Anonymous
  • 770 Answers
  • Posted on May 20, 2008
SOURCE: I had an "f2" error code on Fisher Paykel DD603
i will but need your email address
Anonymous
  • 27 Answers
  • Posted on Jul 15, 2008
SOURCE: Fisher and Paykell DD601 V2 Top Drawer Overflowing
I suggest pressing the keylock and power button together, hold for 5 secs, the display will change orange, the display should read HP if it says LP, press the start button to make display read HP.Then press power button to store. You will need to manually removed the water from the machine before restarting
1helpful
Dd603 bottom drawer locked shut, no displays with power on. How do I get the drawer open?
The thermal fuse that cuts of power to the drawer has been tripped. This means you will need to replace the heater assembly at the base of the drawer. It is not cheap - could set you back by $350-400 to replace.
To open the drawer you need to turn the mains power off and then simply pull the drawer out with a little force. The lid seal is jammed shut because the lid seal actuator motors are locked after the power failed. Do not shut the drawer back as this will damage the lid seal. You will have to call a technician to replace the heater assembly and restore power to the drawer. Hopefully the top drawer is working ok.
How to release locked power button on IIYAMA Pro-lite E1900WS monitor
Just hold down the 1 and Volume down buttons. You will see 'locking power button's and a progress bar in the middle of the monitor. Keep the buttons held down until the progress bar completes. Voila.
DD24DCB6 top drow not working no power
When you say no power, does this mean no function and no lights also? Is there an Icon in the window of that drawer, top right (like a padlock icon)? If so your unit is locked, push and hold the lock button for 3-5 seconds to release.
If not get back to me so we can sort this out.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Hi My F&P dishdrawer flooded. Dried it all out etc, the top drawer doesn't complete the cycle and it beeps continually even when it's not running. I am wondering if I can reset the drawer using the...
Not sure if you tried turning the power off at the main switch. Lock icon can gone away if you press the necessary keys as shown in the user guide. Also the sequence of keys to press for getting factory defaults of different options is also in the user guide. See the long sheets on page 19
Fisher and Paykel dishdraw DS603
look closely at hte display in theright corner is there a little icon that looks like a "lock". if so your control lock is on. do you get any response from any buttons??? if your able to power it up did you try to stop/andrestart unit. sounds like a silly question but sometimes the lid locks down from a power surge/interuption. restarting or canceling current cycle forced drawer to unlock and lock itself..assuming this is the top drawer is the bottom functioning ok??, behind the bottom drawer taped on back wall of inside of unit is atech sheet, with a pretty good troubleshooter. to remove the drawer push in rectangler hinge locks in hte bottom front corner of drawer front, just below the circles(no noeed to remove the circles)push themin and slide back the drawer will lift off and your able to set it aside(wont come out to far its connected by the hoses but itll come out enough(reset the door unto the hinge slides and pull hte lock latch foward to lock back into place
1helpful
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Top Fisher and Paykel Dishwashers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
