I get a message telling me that my memory card is full. I know that I have nothing on it and I tried to format it. That did not work either.I tried a new memory card with no success. What else can I try to fix this? It was working fine on my last trip and just died when I was taking another picture.It worked great on taking previous picture just seconds before.
SOURCE: Memory Card Format Fail
Never format a memory card using windows. Always use the camera to format it.
In genereal though, cards do not need formating before use, the camera will sort this out for you
SOURCE: Kodak Easyshare CX7430 losses memory when shut off
I had this same problem. I couldn't get my camera to take anymore pictures while using my SD cards. So alls I did was took my cards to walmart, put all my pictures on a cd and then inserted my card again, when it brought up formating I okayed it to delete all the pictures since I already got them put on a disc. Once I did this is worked fine. Your cards can only hold so much depending on the size of your card and if you have to much on it your camera will not read it. Hope this helps you.
SOURCE: won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
SOURCE: My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
SOURCE: Kodak DX7590 not reading memory card...
hi. if you can open the camera specially in cards slot, try to desolder and resolder the card slot.some time the loose contact of the pin between the board and cardslot are cause of problem like fromat your memory card,cardlock and not readung the memory.
goodluck my friend
