Question about Casio JF-100TE Calculator
How to set decimal point - Casio JF-100TE Calculator
Set the decimal point to dollars
Dear Anita,
Here is how that works.
A decimal point goes just to the right of the number indicating the amount of dollars you have.
For example, if you have 10 dollars, the decimal point goes to the right, like this: 10.
After that decimal point you put the numbers telling how much cents you have.
If you have 15 cents, it will look like 10.15
I hope this helps you.
God bless your efforts.
Oct 11, 2018 | The Office Equipment & Supplies
HP 14B need to set decimal point
Shift (yellow) button and DISP (above close parenthesis).
N button.
Will show FIX _
Input required number of decimal places
That's it!
Feb 13, 2014 | Office Equipment & Supplies
Need to fix decimal point
Got to program mode press keys, [1], [2], [R/A]. This sets the decimal point for 2-decimal places.
May 28, 2012 | Royal 500DX 16-Department with 999 PLUS &...
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
How to set decimal setting?
Press 2nd [FORMAT]. Press 0-8 for the number of digits after the decimal point, or 9 for floating-decimal, followed by ENTER. Press 2nd [QUIT] to exit.
May 19, 2010 | Texas Instruments BA-II Plus Calculator
I AM HAVING TROUBLE SETTING THE DECIMAL SO WHEN I PUNCH IN 2502 IT COMES OUT AS 25.02
Have you tried messing around with the decimal setting and setting if to F (floating) or somethings besides 2? This should affect your inputting of numbers however. You're not hitting the percent key (%) by any chance, are you. I don't have this calculator but I'm not aware of any function that inserts a decimal point in a number that you enter (other than the percent key). The decimal setting should only affect the number of decimal points in the answer. Good luck and let us know how you make out. I'm curious.
Mar 07, 2010 | Sharp EL-1197P Calculator
How to set up four decimal point for TI-83 plus? Mine right now is 2 decimal point.
Do you mean four places behind the decimal point? Page 21 describes setting for fixed decimal point 0 thru 9 places to the right.
http://education.ti.com/downloads/guidebooks/graphing/83p/83m$book-eng.pdf
Nov 24, 2009 | Texas Instruments TI-83 Plus Calculator
SETTING UP THE DECIMAL ON NEW 210 TM
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
May 05, 2008 | Office Equipment & Supplies
Display a decimal point
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
May 10, 2007 | HP 12c Calculator
Casio JF-100TE Calculator Logo
50 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
