Printer was borrowed for a couple of days, friend says she "didn't do anything" but now it will only scan & copy but not print, as though it has been set to copy by default. I am new to computing, have tried everything I can think of but cannot get it to print. Can you help? Please!
SOURCE: computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
SOURCE: Printer will copy and scan but will not print anything from internet
copi driver instal to my computer
SOURCE: my Hp Deskjet F4200 series printer will not scan
Check to see that your Scanner drivers have been installed. Click on Start, then Printers and Faxes and see if a Scanner is listed. If not, you need to install the drivers.
Also, when you uninstall the printer drivers, you first need to disconnect the printer from the computer, and unplug the printer from the power source. Leave the printer unplugged for at least 15 minutes to clear the printer's cache memory.
Next, go to Add/Remove Programs in your Control Panel and uninstall the printer software. Then, turn off your computer.
Next, reboot your computer. Place the Deskjet cd in the drive and follow instructions for reinstalling the printer software and drivers.
CAUTION: DO NOT PLUG IN YOUR PRINTER CABLE TO YOUR COMPUTER UNTIL PROMPTED BY THE INSTALL DISK!!
SOURCE: I have a Mac OS X 10.6.4 & an HP Deskjet HP
I had the same problem, found out that you should not install the disk that came with the printer. If you do it won't scan. The drivers are already in Mac OSX. You have to uninstall whatever you installed...throw the disk away. To scan go to System Preferences, click printer, then scanner button and it works. Hope this helps!
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
