SOURCE: service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
SOURCE: i have a lanier ld425c
Hello!
I am not 100% sure but i think you can calibrate your touch panel.
Follow this steps:
- Press yellow key.
- On the key pad press 1999.
- Press Red Key five times.
After that you will see the option to calibrate your panel. You just need to follow the wizard.
If you have any dought reply to me.
See you!
SOURCE: Why am I getting lines on my prints when I go thru the top feed of my Lanier LD425C?
Clean the **** glass. It is a long skinny glass to the left of the big rectangular glass under the feeder. Clean it and your problem should go away.
