Computers & Internet Logo
A
Anonymous Posted on Jan 18, 2014
Were do I connect the monitor to the dell precision t3500
Ano Nymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 19, 2015
Ano Nymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1811
Points
10
It's simple. If you still have a problem please take a look at manual in pdf file for this dell t3500. You can find it here for example:
User manual for Dell T3500
4 Related Answers
Computer Links
  • 2386 Answers
  • Posted on Jan 10, 2011
SOURCE: The computer DELL Precision T3500
Hello
To work around the hibernation (S4) problem, temporarily turn off the Hibernation feature. To do this, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Power Options.
  3. Click the Hibernation tab.
  4. Click to clear the Enable Hibernation check box, and then click OK.
Hope this helps, if so do rate the solution.
Anonymous
  • 721 Answers
  • Posted on Apr 30, 2011
SOURCE: how do you remove the
http://support.dell.com/support/edocs/systems/wsT3500/en/SM/td_opthd.htm
All the info you need. Very easy to do.
Anonymous
  • 114 Answers
  • Posted on Sep 06, 2011
SOURCE: Dell Precision T3500 Press
Try running diagnostic test press the power and the windows key at the same time and it will run in diagnostic mode and hopefully that will reveal the trouble. Also, you may wish to try reseating the memory.
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Feb 18, 2013
SOURCE: dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Shut down your desktop computer. Disconnect the power cable from the computer's back panel. Then disconnect any external devices. Rotate the computer so the back panel is facing you. Attach an electrostatic discharge (ESD) strap to your wrist and its wire clip to the outer casing of the computer. Lay the computer tower on its left side. Press on the side panel release buttons situated on the top and bottom panels. Grasp the side panel and rotate it away from the computer until the internal contents of the computer are accessible. Locate the cooling fan duct near the center of the motherboard. Lift the duct off of the cooling fan so it is in the upright position. Disconnect the fan's power cable from the motherboard. Disengage and remove the retaining clips from each side of the cooling fan assembly. Lift the cooling fan out of the motherboard. Set it aside. Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Use a clean paper towel to wipe the excess thermal grease from the processor's surface. Apply a thin coat of thermal grease to the processor's surface using a cotton swab. This is important; if you skip this step, your processor will fry as soon as you power on your computer. Place the new cooling fan over the processor. Press down on each retaining clip until the cooling fan snaps into place. Connect the fan's cable to the motherboard. Place the air duct back over the cooling fan assembly. Rotate the side access panel downward over the computer's opening. Press down on the side access panel until it snaps into place. Place the computer vertically, and then reconnect all cables and devices to the computer.
My dell T3500 precision not working and led 3 and 4 is on :( can any one tell me what to do ?
https://www.dell.com/support/article/ca/en/cadhs1/sln288786/precision-t3500-t5500-t7500-workstations-diagnostic-lights-and-beep-codes?lang=en
The lights alone don't tell enough to tell you how to fix it ACPI S3
Suspend to RAM Windows Standby State.
Does it boot if you use a recovery disk or an emergency boot DVD or USB stick?
Detach all the hard drives and peripherals, pull out all the memory except one, Try again. What is the result?
Try it with a different memory module alone, Repeat.
See if you can isolate a bad memory module
Or it could be a bad motherboard. Shut down and unplug, Inspect the capacitors on the board. are any of them swollen, split or leaking?
https://www.dell.com/community/Desktops-General-Read-Only/Precision-T3500-error-3-4-loud-fan/td-p/4593093
https://www.dell.com/community/Precision-Fixed-Workstations/T5500-diagnostic-lights-3-amp-4/td-p/6066338
Dell precision t3500 solid Amber light and 1 and 2 were blinking
kindly tell what LED blink
The monitor power buttons wrong color LED.
the PC power case button or LED
the PC 4 LED strip ? POST error coded strip.
The KEYBOARD keys act funny, even blink out codes/?
direct to it":
https://www.dell.com/support/home/us/en/19/product-support/product/precision-t3500/manuals
IS the 9 year old PC dead? I presume so. but is it?the screen is blank and black full time.
T3500 the letter "T" means tower, or desktop.
amber lamps on the unstated monitor, or PC case front. or on some dell PC case it as 4 led, diagnostic strip of lamps, a coded, that?
The manual is free to read, and covers led codes.
I'm answering hyjacker Seun O now,, you too no clues as to what you see, on monitor or the PC itself.
here are common failures, on all 9 years old PCs.
The RTC battery in the PC goes dead, the coin cell inside,
the HDD is bad.
the HDD OS is corrupted. for sure if XP OS.
The monitor is older than 2010 the CCFL backlamps die.
the 12 tests are here.
http://pcdied.com/dead-PC.html
Dell precision t3500 problem boot code light 1-2
Yes, you'll get that error message if SATA Operation (SATA Mode) is set incorrectly in BIOS setup.
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
4helpful
2answers
My Dell T3500 will not install the two extra hard drives i have installed
Go to the BIOS settings and make sure the drives are recognized by the BIOS. Ensure they are set as either Master or Slave drives depending on where they are fitted.
Your OS should, once the BIOS picks them up, format as required.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
