Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
A
Anonymous Posted on May 10, 2017
Ts a v-tech cordless phone Model CS6429-3. When someone calls in the handset lights with caller id showing but can't hear rings and i can answer and talk. Also, the answer machine button says on but when a call comes in, it will not pick up call for someone to answer. When I called the phone, it would just ring ring ring and answer machine would not pick up (answer machine is set to answer call and leave message). Please help me asap. I don't want to buy another phone. Strapped for cash. Thank You, Tammy
5 Related Answers
Anonymous
  • Posted on Oct 19, 2008
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
zappanut
ZappaNut
  • 960 Answers
  • Posted on Nov 24, 2008
SOURCE: VTECH CORDLESS PHONE WITH CALLER ID
make sure the MUTE button is disengaged.
Anonymous
  • Posted on Dec 07, 2008
SOURCE: ID quit registering
I just unpluged the system and pluged it back in. Didn't loose any information and it started working again.
stwill2326
Steve Williams
  • 77 Answers
  • Posted on May 29, 2009
SOURCE: cannot answer phone when it rings
when you lift the handset from the cradle try pressing the line number button on the handset or answer button on the handset.
Anonymous
  • Posted on Jun 06, 2009
SOURCE: When someone calls my phone rings 4 times then
You must turn off your internal answering machine. There should be an on and off button somewhere on the main base.
2answers
How do I identify an incoming phone number?
You need to have Caller ID from your phone Co. 1st. Then when you get a call the number shows up as the phone rings.The handset also has a button called,CID,which you can press and see the last 100 calls you've recieved:)
ABOUT KX-TG6541
maybe if you ring the company name of the phone such as panasonic it maybe broken or read the instructions
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
How to set ringer from 2 rings to 4 or more on v-tech vtcs6114
The CS6114 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
If you have an answering machine connected to your phone, consult its documentation. If you need further assistance, please repost your question and identify the answering machine.
1helpful
Please ..need to know how to get other call on call waiting.. cordless phone 5.8
Adding call waiting as a feature to your telephone can help you take calls that you are waiting for without having to stay off the phone until that important call comes in. With call waiting, you get a beep when you are on another call to let you know that another call is coming in. If you want to take the call, you follow the simple steps outlined in this article.
  1. ep 1 Order call waiting from your phone provider if you do not already have it. Cal waiting works best with caller ID features that give you the phone number and name of the person calling you. Phone numbers that have blocked numbers or use *67 to mask their caller ID will not show up on caller ID.
  2. Step 2 Take a call when your phone rings. While you are talking on the phone and hear a beep, you are receiving another phone call. Using your caller ID function, whether it's on your answering machine or on your handset for the telephone, see who is calling you. If you want to talk to them, quickly press your "talk" button to put the other call on hold or disconnect. Press "talk" again to take the incoming call.
  3. Step 3 Disregard the other phone call if you do not want to terminate the call you are on. The new call coming in may go to your answering machine. Or if you have the call back feature on your telephone, you can simply call *69. Your phone will dial the number of the person whose call you just missed.
  4. Step 4 Use call waiting as politely as you can. You might tell someone who you are talking to that you are expecting an important call and may have to terminate the call abruptly. Call waiting calls should be answered as quickly as you can. After four rings, most phone calls go right to the machine or people hang up. Promise to call your first caller back if you have to interrupt the call
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
1helpful
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mute is turned on cannot hear phone ring. How to turn mute off Mute is turned on . Have no dial tone can't call any one and can't answer the Phone How do you turn mute off?
I can't talk or hear outta my phone. I can dial people but i cant hear them and they cant hear. My phone model Cordless 5.8GHz Edge Dual Handset Phone System with Caller ID:
5helpful
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
4helpful
3answers
CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
