Dometic Rooftop RV Air Conditioner Logo
Posted on May 30, 2009
I have a Duo Therm Roof top Camper air conditioner
Runs fine, compressor comes on, just blows air that is not cool
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
4510
Points
16
How old is unit and does it have refrigerant in it
2answers
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
3helpful
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
1helpful
On my 2004 duo therm rv roof a/c,I turn it on and to listen to it, everything seems fine.But it`s not cooling properly.I have changed the filter,went on roof, removed cover,motor and fan are working...
on the compressor two pipes normaly one must be very cool .and other pipe very hot this means compressor is ok
if not cooling that much means low charge of freon need repair first the leak then recharge with freon.
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Unit turns on but condensor dont kick in
Need to pull the cover off and see if the compressor is comming on.If not have someone with electical experience check the contacter.Sometimes bugs will get under the contacts durring wenter.If it is running the freon is low
Fan will not come on
maybe the capacitor for fan was already busted try to check that.
1helpful
3answers
Duo therm ac problem
Same problem. I have a 2005 on a Rockwood Roo. Worked fine in October 2009. Not working June 2010. Problem is not a freon leak, compressor went bad. I banged the compressor gently with rubber mallet then with a hammer but that did not work. The fan runs, the compressor runs but gets hot. Also no indication of freon moving through system as everything gets warm from the compressor outward.
3helpful
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
