When you turn the machine on you can hear the motor run but the belt does not move
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
SOURCE: My nordictrack a2250 turns on, the incline works,
the motor controller is bad and needs replaced
SOURCE: my belt on my C-2000 stopped turning
1) Lube the deck belt, this happen because the lack of maintenance according with the instr. manual. This produce shut down, for to protect the electronic system. Maybe you have a worn deck belt.
see the video and proceed according. LUBE the rollers bearings too.
3) test the input voltage motor, and if there are voltage, the motor need repair.
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the diagram attached.
God bless you
see the video and LUBE very well .God bless you
