The thread from the needle will not catch the bobbin thread...how can I time the machine.
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
