SOURCE: exhaust pipe comes out white smoke when start bike on side stand
Continuous or just for the 5-10 seconds.
If continuous you may have oil seeping past your pistons oil rings or valve guides oil seals.
Check your spark plug see if they are fouled badly (covered heavily and oily) or just covered by oil and sooth lightly.
If 5-10 sec it is normal as the engine is heating up there are normally a little oil seeping past the seals.
Testimonial: "gives me more understandings on a bmw engine"
SOURCE: the yz 250 1986 has the same engine as the tri z
im not that good with carborators so any help will be great .
SOURCE: RD 250 - I am
Hi people ' if White smoke is continuously coming out of pipes there are many facts and causes first if you are losing power also it may be piston rings worn (2) if White smoke is jetting out when reving engine, depending on the fact that we are talking about 2 stroke engines then check 2 stroke oil mix is measured out before put in fuel (3) check and test 2stroke oil pump for adjustments and reset (4) most important crank case seals give off symptoms of above .. Poor idleling loss of power & compression . Check these areas out . Hope this helps simon R. :)
