I am having the same problem. I have no misting at all, only music and colors. I am going to try moving the glass spout so it's opposite the plastic spout--i read that somewhere. I'm also going to start over again with filtered water. I had gotten into the habit of just reflilling and adding more oils. hope this works and helps you too!!
Hi Once you have finished steaming, turn the steam button off, then open the knob and let the steam out. The water pump will turn on again and bring the temp back down. When the pump changes tone, the light will go off and you can brew again. It takes less than 10 seconds.
Remove the filter and the 2 allen wrench screws that hold the diffuser in place, then carefully remove the spring and valve seat which is probably not in there as they should be, make sure they are seated correctly and re assembly machine. At some thine there was a massive surge of pressure and that moved the valve seat out of place.
i have a steam station , the stand-by light keeps flashing on and off, how do i reset it, there is no steam comin thriugh at all, please help.......thank you xx
