SOURCE: microphone jack
usually it is place at the back of the CPU. the plug color is pink. near the fan. goodluck!
SOURCE: microphone and audio jack not working on dimension e510
look in the sound settings you may find the front panel audio and headphone have been deactivated, or try to re-install the sound drivers again, if there is any on-board audio, go into the bios settings and dissable it
good luck
SOURCE: Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
