When I start the camera "memory card locked" appears on the screen
SOURCE: Memory card locked
Hi everyone,
Here's the solution, I just had the same problem LOL!
1. take the memory card out
2.On the memory card there is a little switch (it will be the little tiny piece on the side of the card thats a different color) slide it up.
That's it!
Bye
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
SOURCE: Memory Card locked: I changed the memory card in
if we are talking about an SD card ...see that in a side ..the card has a slide like button with 2 positions ...locked and unlocked... just unlock it cause it might have been locked when handling it...
SOURCE: Loaded new memory card, and screen reads memory
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
