SOURCE: battery cover won't open
try tapping it or even shake your camera to try and losen battery if not try to force open not enought to break but a firm grip this has happen to me befoe
SOURCE: Canon IXUS 700
There is a switch that the door presses whren closed, without the door in correct position the camera will not start up.
SOURCE: battery/memory card compartment wont close
if it wont shut but still works fine just tape it there! if you think its a serious problem take it to a camera shop to get it checked out?
To install the battery:
Note: To open the battery door, you will need a paper clip or thin pen.
1. Take the paper clip and use the end to press down on the door latch.
2. Holding the latch down, push the battery door up.
3. The door will slide up and spring open, allowing you to access the batteries.
4. Place the battery into the compartment. Be sure to match the (-) on the
battery with the (-) inside the compartment.
5. Slide the battery cover to its original
