3-333 communications failure between the Foreign Interface
and the machine.
Press 0 and start button at same tame.
Enter 6789 and select confirm. Select dc 131 NVM read/write.
select input number an type:
752-002 0 = Foreign Interface disabled 1 = Foreign Interface Enabled
759-015 1 = Addition Device (Auditron) 2 = Subtraction Device (Debit card)
if you want to see current value select "read"
I am having the toruble shooting manual for the same
SOURCE: error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
SOURCE: Error code 11,009,46:1444 on Xerox Phaser 8500
the 11,009,46 error in my experience means that, at some point, the printer lost power during an electronic action. in some cases an NVRAM reset will do the trick, but if it doesn't, one of the electric boards has been blown up. XEROX are very protective about which board to replace, so you're quite stuck with their own service in order to have it repaired.
