Uniden TRU9480 Cordless Phone Logo
Posted on May 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Caller ID doesnt work anymore
My cousin make some adjustment on the phone after that the caller ID doesn't work anymore. did he delete or does something wrong? Can any1 help? thank
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
423
Points
My caller ID doesnt work anymore it wont hold the numbers and the names
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Jun 01, 2009
Anonymous
Expert
Level 2:
Answers
61
Questions
0
Helped
18035
Points
149
See if it is turned off at the provider. ring and ask for the codes to turn them on and off.
1helpful
Have uniden dect 6.0 plug in system and landline .how d we delete 101 calls from the uniden after they have been dealt with on the land line
I believe you are asking how to delete the call ID log<?>.
If you can identifiy the (caller ID/right) key on the large round multifunction button of the handset, do the following.
To delete all the Caller ID numbers, press (caller ID/right) key when the phone is in standby. Press MENU/SELECT and select
Delete All. When the phone asks you to confirm, select Yes.
Notes:
• When you delete a Caller ID number, you delete it permanently.
• Caller ID numbers are stored separately in each handset. Deleting a record from one handset will not delete
the record from any other handsets.
Caller id doesn't work for iphone 4
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
1. Go to settings.
2. Click on Phone.
3. Click on Show my Caller ID, and select Yes.
2helpful
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Phone doesn't show caller id numbers anymore.
You need to make sure you have programmed your area code...check the manual for setting up caller ID. You can search for the manual on line...go to Retrevo.com
http://www.retrevo.com/support/Sony-IT-M602-Telephones-manual/id/751bh629/t/2/
Are caller ID units interchangealbe between 2 homes?
The caller Id service is a paid extra. If you have a caller ID phone, and are not a subscriber to the service it will not do you any good.
Turning caller id off doesnt always work.I call my cell phone and it picks up the number. If this was a constant fault I could understand but its intermittent so without making any changes sometimes it...
If the number is programmed into your phone then it will always show the number. Delete all of your contacts and your caller ID will no longer work. I am assuming this is what you want.
Caller id dont work
just connect one end of the phone plug to the id caller,then connect the outlet of the caller id and fix it to phone...........even then if u hav problem, may be ur caller id doesn.t hav batteries..............otherwise u may hav some problem in the id caller socket where phone plugs r inserted................
Caller ID doesn`t talk
only thing i can think is the IP function might be on. ( and of course, u do have the caller id through the phone company activated, right,,,,just checkin) . this funtion is not available in the USA. to turn it off, press SET/SAVE, press UP to select SET 4 AUTO IP, press SET/SAVE to select, press UP to turn on and off, then press SET/SAVE to confirm. hit DELETE to return to main screen. hope that helps.
tammy
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
