Question about Planar PT1510MX Monitor
Touch Screen not working
The touch screen stopped working. I can not find the touch screen option at all on the computer now.
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Nov 24, 2015 | Lenovo Computers & Internet
How do i turn off a my sony all in one touch screen, i do not touch the screen for options, and its driving me crazy
  1. Press the Windows logo key + X.
  2. Select Device Manager from the list.
  3. Click the little arrow next to Human Interface Devices to expand the list.
  4. Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
  5. Right-click, and select Disable from the list.
  6. Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
  7. Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable See the website
S
SeS Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO Tap 20" Touchscreen All-in-One...
Touch screen not working
is it just the touch that stops working? or all off the computer?
May 22, 2014 | Toshiba Satellite Computers & Internet
Monitor work but touch screen stop workig
the capacitor u changed might be the problem ... contact ur vendor for support
Mar 29, 2014 | Planar Pt1550mx-15" Blk Touch Screen
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 07, 2014 | Minolta bizhub 200 Copier
Acer Aspire Z5610
You may try inserting a wireless or wired mouse in to a USB port to get some activity. As long as your screen comes up, the movement of the screen should be taken over by the mouse and temporarily bypass the touch screen application. You need to go to Acre, at their Web Site and download the drivers to allow the touch screen to operated. If after all your efforts fail; the unit needs a professional technicians services.
Dec 22, 2013 | Acer Aspire Z5600 Z5610 Z5700 Z5710...
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
The touch screen on my lg chocolate touch has stop working
Hi there
Welcome to fixya
If the touch screen is not working then one of the wires on your lcd might have come loose your best option would be to take your phone in for repairs
thank you for using fixya
regards
magical ink
Aug 15, 2010 | Cell Phones
Lanier LD435c touch screen is not registering touch in right plac
Press the yellow clear modes button then press
1 9 9 3 and the red clear/stop botton 5 times
this will open up the touch screen calibration menu
select calibrate touch screen. follow on screen directions.
Good Luck
Apr 08, 2010 | Office Equipment & Supplies
Leapster
To determine if there is an issue with the touch screen, you need to
follow these steps:-
* Turn on the unit and select any user.
* Select 'Option' from the keypad.
* Then select 'Configuration'.
* Scroll down to select 'Diagnostics”.
* Scroll down again and select 'Touch Screen Test”.
If you can complete the 'Touch Screen Test ', it implies that there is no issue with the touch screen. The most effective way to use the touch screen is to select using the tip of the finger or with a blunt end of a pen or a stylus. However, if you cannot complete the touch screen test, it would imply that there is a problem with the touch screen.
Dec 31, 2007 | Magellan RoadMate 700 GPS Receiver
Planar PT1510MX Monitor Logo
26 people viewed this question
Top Planar Computers & Internet Experts
Thomas F. Schneider
William Miller
William Miller
Joe Goldman
Joe Goldman
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
