Freezer not keeping food frozen, ice on back wall. Removed all food to other freezer and unit is making rattling sound. Model 70287990 Kenmore top mount freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
