The noise is independent from the volume knob and is constant in volume. When the woofer receives input, the noise is reduced, especially at high volumes, but returns when the volume is turned down or there is no input again
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
Thank you for this. I will try this. Otherwise I am considering tearing out the digital amp and replacing it with an equivalent analog amp to drive the elements
