Service manuals electronic components datasheets and equipment schematics...
try thi site for serviice manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
SOURCE: Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
SOURCE: Minolta Magicolor 2430 DL
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
SOURCE: Magicolor 2430DL shows no cartridges
http://www.fixya.com/support/t474251-minolta_2430dl_x_toner_not_installed
SOURCE: have a Konica Minolta 2430 DL and it ask me to
2408
means that the toner cartridge you are trying to rotate to is already
in the top position or you need to install another toner cartridge
before you can rotate to the color you want to replace.
To fix
the toner not installed message clean the three contacts on green chip
on the right side of the toner cartridge. You may see black lines on
them. Use an eraser or rubbing alcohol.
