Hi my laptop shows a white line horizontally across the middle of screen. It originates on the right side of my screen and eventually fades about 2/3 of the way. Any ideas? Thanks, rahman hi my sony VGN-CR21s laptop screen have white line start from right side and fade away to left. please give me solution.
actually it is called a dead pixel. You can't fix it unless you will replace your LCD. Sorry for the bad news but it is for a fact. Hope I have answered your question
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
