Hi after a power problem only the master set rings how do i turn on the rest
thanks
jeff
Here is a link to a web page that gets into extreme detail about the problem you are having: http://www.p1bc.com/macrotel/macrotel_excel_mt16.htm#IMPORTANT
Your battery is dead inside and programming will be lost every time the power goes out. You should do something about the battery either way so it does not damage your system but you can get away with a UPS backup power supply.
You should look for a manual to re-program your system. It's worth the small expense if you plan on keeping this system for any length of time. There is a link on that web page I provided you to buy the manual. (top right side)
Power was out - we have 3 phones and now only 1 set rings - the date and time are off and can't seem to correct that either.
We had a power outage at our office and the phones aren't ringing. The lines flashing when a call comes in and we have to press the button to answer the call. We tried programming it, turned off our main switch and no results. We really need this to be fixed because
