I can't buy certain apps from the app store or download anything on my iPad 1 because my iOS is less than 6.0. Is there a way I can upgrade to at least 6.0?
NO
- iOS 6 and higher is not compatible with first gen. iPads!
First gen iPad not getting iOS 6 update Apple confirms
SOURCE: My WritePad app for IPAD no longer separates
If the spacebar on the keyboard isn't there (with .com and underscore keys etc instead), you're in the URL-typing keyboard instead of the normal one. Try clicking the @ icon in the bar just above the keyboard to change modes. In handwriting mode, it's the same thing...click the @ icon near the left side of the bottom bar.
SOURCE: How to upgrade the Flash Player on my iPad 2?
Apple's iOS devices such as iPads, iPhones, and iPods do not support flash. This is the reason that installing from Adobe failed.
SOURCE: How to delete apps on an ipad
To remove/delete an app from your iPad, do the following:
Note: The deleted app will remain in your purchase history in the event that you ever want to re-install it.
SOURCE: Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
SOURCE: how to install ios5 on ipad2
Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
