Question about Rotel Audio Players & Recorders
Where can we buy the remote of RSX 1067 7IN1
Hello, I would like to ask if where can we buy the remote of RSX 1067 7IN1 since this was only given to me without remote and I have a problem with its volume because even we max it up the sound is still low. So maybe it has something to do with the remote? Help please
    Sergeant:
  • 257 Answers
I do not know anything about your brand or market, but I have had good success with replacement remotes at http://www.replacementremotes.com/
They have a very wide selection of mostly refurbished remotes.
Originally supplied with RSX 1058 is this:
http://www.replacementremotes.com/ROTEL/Buy-RR-1061-RR1061-Audio-Remote-Control.html
Posted on Jan 18, 2014
4 Suggested Answers
SOURCE:
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
dunnbiker
  • 8546 Answers
SOURCE: Volume really low, even when turned right up
So the speakers and the individual amp channels work so that lets out the obvious big hardware items.
This is starting to sound like an obscure setting was set or changed by mistake.
It would be nice to figure out what that is/was in case it happens again but you may eventually have to resort to resetting the receiver to factory defaults and start over by holding the1/0 button for 5 seconds.
Posted on Mar 05, 2010
cyberfast
  • 155 Answers
SOURCE: Volume through speakers is very
check that all the speaker are connected right. some systems won't work right in 6.1 if its not connected right. (please rate me if this helps Thank you)
Posted on Dec 22, 2010
Why my URC SL-9000 can not control ROTEL RSX-1056 AV Reveiver
Do an auto search method to search for codes. If the remote control have set-up code to your device, you will win. If not, buy an other remote control, which have set-up code/s to your device brand.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 02, 2014 | URC-Universal-Remote-Controls Remote...
Do you have to pull intake manifold to replace starter on 02 acura rsx base 2.0 auto trans
Hello integradub: My name is Roger and I will help. The answer to your question is no. You do not have to remove the intake manifold. But before you start the replacement .MAKE SURE YOU HAVE THE ANTI THEFT CODE FOR THE RADIO. You will need to remove the sub frame dampener and the intake manifold brackets that are in your way. Should you need further help please just ask. Please rate the answer you received as this way I know it was helpful. Thank You for using Fix Ya. Roger
Mar 18, 2010 | 2002 Acura RSX
Where is the starter solenoid located on a 2002 acura rsx
Hi:
The starter solenoid is mounted to/ part of the starter, and you buy it as an assembly.
Nov 22, 2009 | 2002 Acura RSX
Need replacement remotes for Autopage RF-420
www.autopageusa.com. right from the source
Nov 22, 2009 | Vehicle Parts & Accessories
How do i enter unlock code in my acura 2002 rsx
if its for radio sometimes dealer will ask for some model no# on your radio and he can give you code to unlock it..sometimes they charge either sometimes you cant win
Nov 01, 2009 | 2002 Acura RSX
Check engine light on a 2002 Acura RSX
Just hit the reset button, i have a 03 Civic Si same motor as base RSX mine came on everytime when i kept disconnecting the plug, never came back on. (i have a short ram intake)
Jan 30, 2009 | 2003 Acura RSX
Will this size rims fit?
yes they will fit that car can go up to a 19in rim
Nov 16, 2008 | 2004 Acura RSX
167 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
