I am not very sure which ATI you meant, but I assume myself as ATI Mobility Radeon HD 3650 MXM II Graphics Card 512MB, which is compatible with MXM II graphics slot Laptops. It's a good graphics card and it supports high Resolution. For your reference, I include the following descriptions about the Interfaces and their respective resolutions:
# Two integrated DisplayPort outputs
* Each supports 24- and 30-bit displays at all resolutions up to 2560x16001
* 1, 2, or 4 lanes per output, with data rate up to 2.7 Gbps per lane
# Two integrated 400 MHz 30-bit RAMDACs
* Each supports analog displays connected by VGA at all resolutions up to 2048x15361
# HDMI output support
* Supports display resolutions up to 1920x10801
* Integrated HD audio controller with up to 2 channel 48 kHz stereo or multi-channel (5.1) AC3 supporting Dolby Digital or DTS, enabling a plug-and-play cable-less audio solution
# Integrated AMD Xilleonâ„¢ HDTV encoder
* Provides high quality analog TV output (component/S-video/composite)
* Supports SDTV and HDTV resolutions
* Underscan and overscan compensation
# MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding
# Seamless integration of pixel shaders with video in real time
# VGA mode support on all display outputs.
You can also check out the full specifications here
(Click Here).
Let me know if you need further help.
Good Luck.
Thanks for using
FixYa.
