You also may want to take a close look at the control panel. I found a grouping of 3 resistors at approximately center of the board that were cut on one end. Probably a design change poorly done. Somehow, just out of the blue, those loose ends touched and blew that fuse. Removed resistors........problem solved.
SOURCE: NEED BRAND NEW Emerson MW8111SS
Check this link: http://www.walmart.com/catalog/product.gsp?product_id=2584483
SOURCE: Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
SOURCE: Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
SOURCE: Emerson Microwave Model MW8119SB found blown
Chances are that either the diode or capacitor are shorted. Be very careful, the capacitor can store a charge and should be discharged first for safety. Hope that helps...
Geno
