RC Thomas the Tank Engine Logo
A
Anonymous Posted on Jan 17, 2014
Can you put a 12 volt battery in it. My 1 1/2 year old weights 38 lb. I would like that he got 2 or 3 summers out of it for the price.
38 lbs and I want him to get 2 or 3 summers out of it for the price.
Ivan Maric
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on May 05, 2014
Ivan Maric
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
6241
Points
38
The short answer is no. Unless you want to burn the motor and control circuit. I had a lot of problems with Thomas going slow, not having enough power, like battery is dead, until I figured out that there is too much voltage drop on the "dead-man" press-down switch. See my other post how to replace it with home wall mount flip switch from Home Depot. Other place to look is under the seat and make sure that motor contacts are clean, no corrosion and that they are not loose. I soldered them in place. another spot is the battery connector to check that it is not warned out.
If you want higher voltage and higher speed, you can go to any hobby store, or online, and by some of the airplane or care NIMH battery packs, like 3300mAh, 7.2V (they are made of 2/3-C cells, JFYI).
I use two 3000mAh, 7.2V, in parallel, just because I got them cheap (usually they are $10-$20 specially when they have sales). BTW, the original led-acid gel battery is about 6000mAh-when brand new.
You will probably need to change connector on the train (I switched to "T" also known as "Deans". If you know how to solder, or ask in the shop, some will do it for you if u bring ur train in. You can by a cheap charger in the hobby store, or use any 9-15V wall brick and use resistor to set current to around 1/10 of the battery capacity (200-300mA) for 12h charging time.
You can also choose 2-cell Lithium polymer battery (6v-8.4V empty/full) , they are more expensive, but light and bigger capacity in the same space. Thsi is excellent option if you already have them fo your hobby. Important: If you choose LIPO, you will need a charger designed for LIPOs or you will cause fire. If you never dealt with them, just stay away from them. Can you put  a 12 volt battery in it. My 1 1/2  ye - 4b2cc156-dc6c-44b5-b8d0-db1399575ac6.jpg 1ec09f13-006a-42ed-a051-7e431351e43e.jpg
1helpful
What is causing the battery to drain?
Running the car will drain the battery it if it's not charging ! An if your charging light is on it isn't charging ! Did you check power an grounds on the alternator ? There is a single heavier wire on the back of the alternator, this should have battery voltage ! You may want to take this to a ASE certified repair shop !
Functionality
With the ignition switch in the RUN position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 35 (OG/LB) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator S circuit 4 (WH/BK). This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output (B+) Circuit 38 (BK/OG)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit 904 (LG/RD) is used to turn on the voltage regulator. This circuit is powered up with the ignition switch in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 35 (OG/LB)
The A (battery sense) circuit 35 (OG/LB) is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
S Circuit 4 (WH/BK)
The S (stator) circuit 4 (WH/BK) is used to feed back a voltage signal from the generator to the regulator. This voltage is used by the regulator to turn off the charging system warning indicator. The S circuit is fed back externally on external mounted regulator generators.
Visual Inspection Chart Mechanical Electrical
  • Battery case, posts, hold-down clamp, cables and connections
  • Generator drive (serpentine) belt for condition and tension to make sure there is no slip between the belt and the pulley. For additional information, refer to Section 303-05 .
  • Battery charge
  • Generator pulley
  • Battery junction box (BJB)Mega Fuse
  • Battery junction box fuse:
    • 11 (20A)
  • Central junction box (CJB) fuse:
    • 30 (30A)
  • Circuitry
  • Charging system warning indicator
  • Cables
  1. Check the operation of the charging system warning indicator lamp (instrument cluster). Normal operation is as follows:
    • With the ignition switch OFF, the charging system warning indicator should be OFF.
    • With the ignition switch in RUN and the engine off, the charging system warning indicator light should be on.
    • With the engine running, the charging system warning indicator light should be off.
  1. Verify the battery condition. Refer to Section 414-01 .
Normal Charging System Voltages and Charging System Warning Indicator Operation Ignition Switch Position A Circuit 35 (OG/LB) S Circuit 4 (WH/BK) I Circuit 904 (LG/RD) Generator B+ Circuit 38 (BK/OG) Battery Engine to Battery Ground Charging System Warning Indicator Operation OFF 12 volts 0 volts 0 volts 12 volts 12 volts 0 volts Off RUN-engine off 12 volts 0 volts 1-3 volts 12 volts 12 volts 0 volts Illuminated RUN-engine running 13-
15 volts 1/2 battery voltage 13-
15 volts 13-
15 volts 13-
15 volts 0 volts Off
  1. If the customer concern is verified after the initial inspection, refer to the Symptom Chart to determine which tests to carry out.
    • The charging system warning indicator is on with the engine running (the system voltage does not increase)
    • Circuitry.
    • Voltage regulator.
    • Generator.
    • GO to Pinpoint Test B .
    Your whole problem is the alternator is not charging , a couple tests with a volt meter would tell you !
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
3helpful
Need to the torque specs for a 1999 Dodge Durango
Head Torque sequence Step 1: torque to 50 Ft/Lbs Step 2: torque to 105 Ft/Lbs recheck final torque in sequence.
Torque intake manifold: Step 1: 12 inch/Lbs, (hand tight) Step 2: 72 inch/Lbs, (6) Ft/Lbs Step 3: 12 Ft/Lbs
torque intake plenum: Step 1: 24 inch/lb (hand tight) Step 2: 48 inch/lb (4) Ft/Lbs Step 3: 84 inch/lb (7) Ft/Lbs (To torque bolts, start in center using crisscross pattern)
2answers
93 plymouth voyager
divid by 12
1 ft lb = 12 in lbs
Top RC Toys Experts
NOEL
NOEL
john h
Are you a RC Toy Expert? Answer questions, earn points and help others
