SOURCE: Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
SOURCE: my freemotion treadmill is slipping,
ajusting the belt tension rollers, front and rear rollers tighten with usually a allen bolt ajustment tool
SOURCE: Freemotion 790 Interactive treadmill belt squeaks as soon as you turn it on
Inmediately LUBE the deck belt, this happen because the lack of maintenance schedule, see your instr. manual and follow the steps.
2) Lube the rollers bearing use the wd-40
see the video attached.
God bless you
