Turn breaker power off. Verify now power to unit with volt meter. Most systems have in line over temp over current to protect circuit board and motor. Also the water level switch must be made to complete interlock condition. Check the heater coil for continuityas it may have opened. Check heater for continuity to each coil set. There is an interlock that is for diagnostics on start up that will prevent unit from starting. Look for any melted wires or components too. Always know and verify breaker settings. Verify your meter with known voltage reading first. Be safe my friend.
SOURCE: SN ?Non Functional High Temp Sensor? error message
unplug and plug after 20 sec. turn pump fast and wait for 1 min if nothing air is trap anf need to be out
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
SOURCE: Tonight my master temp 250 heated the spa to 80
You are right about the ignitor. Depending on how old your heater is. The ignitor can become weak and flame rectification will be intermittent. You may have to replace the ignitor assembly or at lease check to see that it's not corroded enough to impede gas flow.
Testimonial: "Thanks for the confirmation."
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
SOURCE: rs265...both sides will cool down/freeze
Thats sounds right. These digital frigs are very nice except when you are trying to fix it!!! Expensive!!! Call Samsung and ***** like you never ***** before!!! this is unacceptabullshit!!! Tell them (even if it is out of warranty) that Consumers Report we love the negitive review you will give them if they dont come out and fix it!!! There should be many peolpe complaining about the same problem They can even send you a voucher check for a new one. Why not they have billions!!! You have to be pissed and demanding.
