Please, information and date quest watch. thank you brazil
SOURCE: watch casement cover replacement
looking for a battery cover to suit model D 377 tissot men's twotimer II vintage 1992.
SOURCE: How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second
hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown
all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands
will stop.
Step 2. Turn the crown to
move hands FORWARD (clockwise) until you see the date (for date only) or both
day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue
to move hands forward until the minute hand is approxim a t e ly 5 minutes
beyond the desired minute marker ;then ,gently turn b a ck to the same marke r.
For P. M .time , follow the same procedure ,but first a dvance the hands past 12 o’clock .
N O T E : The date will
advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been
established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The
refore ,on the fi rst day of any month
fo l l owing a month with fewer than 31 day s , the date must be advanced
manually (see Step 5).
Step 4. When the time
standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches
the 60th second, push the crown all the way to the “ I N ”position . All hands
will start instantly.
Step 5. Pull the crown to
the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will
continue to tell time. S l ow ly turn crown one way until the correct date a p
p e a rs .Then for day/date models, s l ow ly turn crown the other way until
the correct day appears .
N O T E : The day is printed
in two successive positions on the day indicator: i n English and in Spanish on
U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is
possible to make use of either position. The display will automatically re m a
i n in the language ch o s e n .
The
date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M
.a s this might affect the calendar mechanism and the accuracy of the date. (
Theme chanism will not be damaged if the crown is turned accidentally during
this
time
peri o d ,howeve r. )
Hope it helped U!
SOURCE: how to quick set date on n5 accuquarz bulova watch
Hi friend i am providing a link I hope this will help you out.
http://reviews.ebay.com/How-to-set-day-date-on-Bulova-Accutron-2182-movement_W0QQugidZ10000000006982861
Gud luck.
SOURCE: Bulova 14k Solid Gold woman's watch. Swiss 17
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
