125cc semi auto 4stroke pit bike new coil lead spark plug racing cdi unit air filter and exhaust
Tryd go to auto shop and check the carburator of your motor and clean your air filter adjust air setting in carburator and put a new fuel pump check fuel setting in carburator
Ok air filter is new but did think it was air screw and gas screw needed adjusting
Would the air flow and gas flow stop the bike from kicking ova ive turned both screws hard right then done two full turns but still no combustion
I adjusted air and gas flow screws went to kick start and kick start will not kick over now starts to lock up
SOURCE: No spark on Piaggio zip
Is the kill switch on? Check the side stand kill switch if you have one. They sometimes go bad. Disconnect the handlebar kill switch. Does it start now? Also check the key switch. A switch can go bad as well.
Please rate this solution. Thanks 01richardobr!
SOURCE: 07 ktm 450sxf wont start
take your carb out, clean the entire thing, that means every nook in that *****. do this and if still a problem write back because in most cases were n idiot is involved, this is the most over looked problem
