Question about LawMate PV-500 LITE Portable DVR
Lawmate not turning on
I have a law mate 500 lite that will not switch on. The battery is fully charged and I get a red light that goes off after about an hour but the unit will not turn on . colin.reed93@ntlworld.com
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
It doesn't seem to keep the charge. does that mean I need a new charger or a new headset?
Sounds like the battery is not holding its charge.......you can rejuvenate the battery by fully charging and then fully draining til it goes off either by leaving on or using! Doing this a few times will allow the battery to fully charge and hold the charge better!
Feb 04, 2015 | Radio Communications
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
Power supply not lasting long whats wrong with it
to have a proper full charge is 3 hours even tho the light might go off to indicate its filly charged. have you had it a while because according to nintendo the battery life drops by 25% after 500 charges and so on. you might be as well getting a new battery at around £3 on ebay
Jan 21, 2010 | Nintendo DS Lite Console
My DS lite wouldnt switch on whilst i was on it so
It sounds like a faulty on off switch, when you turn it on it is not contacting fully, i had this problem with my grandsons ds lite, what i did was unscrew the ds, then looked to see if the push up and down on off switch was fully contacting when switching on, when i took the case off i could turn it on, i just made sure everything was in place and put the case back on, its ok now, i could be the on off switch had dislodged ater time, and just needed re locating, its nothing to do with getting a new battery.
Oct 15, 2009 | Nintendo DS Lite Console
When i try to power on my son's DS Lite, the red light is on, and both screens power on for about 2-3 seconds max and then the system shuts off. It also wont charge when connected to the wall.
You may need to get a replacement battery pack when the battery is below 30% the light will turn red, the battery requires 4 hours to charge, and when the battery is fully charged the amber colored light will turn off. If you still need to purchase a new battery contact nintendo cust serv at 800-255-3700 or you can order online at nintendo.com You will need a #00 philips screw driver to remove the battery cover, install the battery with the 2 tabs in first, close compartment and allow battery to fully charge before use. The average battery will last for about 500 charges. Hope this helps
Aug 05, 2009 | Nintendo DS Lite Console
Putin in charger orange light flashes then goes off an doesnt cha
Your DS is either fully charged or the battery got damaged/wet. When you play the DS, is the light red or flash red? If it does, then the problem is with your battery. http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Click on your country, then "System and Game Problems," then "Power and Battery Charging Problems."
Hope this helped.
Apr 15, 2009 | Nintendo DS Lite Console
Ds lite
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
Nov 03, 2007 | Nintendo DS Lite Console
LawMate PV-500 LITE Portable DVR Logo
83 people viewed this question
Top LawMate Video Cameras Experts
Marvin
Marvin
Are you a LawMate Video Camera Expert? Answer questions, earn points and help others
