LG 42LC2RR 42 in. HD-Ready LCD TV Logo
D
David Ahitov Posted on Jan 17, 2014
LG LCD 42" sound but no picture
Hi guys, my LG 42" turns on with sound but no picture When i turn it on i can see the back light is working, and i can hear sound but no picture. Sometimes there is picture for a very short period (like 0.1 sec) but then it turns black again. Also there is the power light (red when off white when on like it should be) but when i click something like volume up or input it should blink for a sec (indicates the the tv reads the click) but now it just turns off (not the tv, the power light). I have done some research and opened the tv to look for some bad capacitors over the power board but the seem to look fine... What can cause this and is it repairable?? I would really appreciate any sort of help :) Model: LG 42LC2R-ZH Main Board: 68709M9004 (PP62ABC/LP62ABC) Power Board: 6709900017A (YP4201) Rev 1.3
Roger-Cyndy Wilber
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 10 Answers
  • Posted on Jan 17, 2014
 Roger-Cyndy Wilber
Contributor
Level 1:
New Friend:
Night Owl:
Answers
10
Questions
Helped
2005
Points
22
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
5 Related Answers
Anonymous
  • 133 Answers
  • Posted on Jan 10, 2009
SOURCE: LG 42 plasma power problem
needs power supply Part number 6709900023A
it is a 171 dollar part, you should be able to order through LG,
Anonymous
  • 227 Answers
  • Posted on Jun 24, 2009
SOURCE: Turn the TV on, clicks back off - no sound, no picture
hello, your power supply has to be repaired and you are looking at $275.00 for this job
good luck
Anonymous
  • 5 Answers
  • Posted on Aug 31, 2009
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
John W
  • 11 Answers
  • Posted on Dec 19, 2009
SOURCE: I have a 42
There are 4 capacitors on the power supply board that need to be replaced. They are green in color. There is also another green capacitor made by the same company in that area that also might need to be replaced also.
Paul
  • 381 Answers
  • Posted on Mar 26, 2010
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
No picture but sound on LG 42
Your back light inverter is bad. The backlight inverter is the board that turns on the lights on teh back of your screen so that you can see the image.
You can get get parts for this tv at www.interliquidparts.com
Turned on my 42" LG
hi,
Yor tv has problem with back lighting. This tv uses LED (Light Emitting Diodes) as back light. These back light modules are not availabe in the maket now. You have to contact the authorised servicing centre for the same. You will get an idea how it works by the help of following picture.
HI WHEN WE TURN OUR LG 42 INCH LCD TV ON IT WORKS OK FOR ABOUT 30 MINUTES THEN THE PICTURE GOES AS THE SCREEN GOES WHITE THE SOUND WORKS FINE AFTER ABOUT A HOUT THE PICTURE COME BACK AND IN OK ...
I suspect you have a poor contact on the video processor board or the upscaler itself on the screen.
Check all ribbon connectors and look for any components that have got very hot, there may be a dry solder joint beneath them.
Hope this helps.
1helpful
I have no picture. Sound & Signal are working
It seems back light inverter board is not producing voltages to lit the back light inside lcd panel to show the picture on lcd screen.
Please replace back light inverter board to get tv fixed. Local tech will help you if you are not familiar with tv repair.
Thanks.
1helpful
2answers
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
1helpful
No picture or sound on LG 42" Plasma
Hi Craig,
Your Tv has a 1 year warranty, you should contact Customer Service as soon as possible. This is the number in the USA 1-800-243-0000
If needed this is the Global Site. www.lge.com/products/category/list/tv.jhtml
Enter your country then click on Support for the Service Number.
If this helps please rate this solution as a FixYa.
Lone99star
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
