Alpine CDA-9847 CD Player Logo
A
Anonymous Posted on Jan 17, 2014
Cant connect to my phone
I don't know how to use the Bluetooth
Bluetooth passkey
Reset all bluetooth options, and enter new password when connecting to other device.
1helpful
How to connet bluetooth on nokia 5230
Bluetooth is a wireless technology that allows devices to communicate via high-frequency radio signals. Bluetooth headphones are just one of the many devices designed to work with portable music devices as well as ordinary phones. With Bluetooth headphones, you can listen to music as well as make and receive calls--all from the same device. Connecting them is a snap.
  • Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
  • 2
    Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
  • 3
    Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
  • 0helpful
    Trying to pair my bluetooth with my phone and it' asking for a pass code i don't have my manual so I don't know what the code is
    when u connect ur phone bluetooth to any other device it need a pass code! you have to give that from ur phone manually and the other device should have to put the same code so now u use the headset option to connect to the bluetooth not the normal bluetooth conectivity !
    Sep 16, 2011 • Cell Phones
    1helpful
    How can i connect my bluetooth headphones
    Things You'll Need
    • Bluetooth capable phone
    • Bluetooth headphones
      • 1 Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
      • 2 Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
      • 3 Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
    Jun 12, 2011 • Cell Phones
    My speaker have water damage, i can hear but they cant hear me, can i use blue tooth
    Hi, a blue tooth device would allow you to hear and speak through it so it should solve your problem.
    the only problem you may have is if the water damage has causes damage to bluetooth inside the phone, try choosing bluetooth on your phone and see if you can still do a search and connect with another phone, if you can still connect to another phone to say send music or picture via bluetooth then this would suggest your bluetooth is fine and using a bluetooth head set will solve your problem and allow you to use your phone again.
    if you cant connect to another phone via bluetooth then the chances are it wont pick up the bluetooth head set and you would be no better off
    let me know how you get on or if you need further assistance ok
    please rate this solution as i have a whole page of unrated posts, thanks
    2answers
    I cant talk to anyone and how do you talk to them
    Check to make sure that the bluetooth headset is compatible of connecting to the mobile device. If it is, then you will need to pair the devices using the Mobile Device. Make sure the Bluetooth Headset is switched on when the Mobile Device is trying to search for the Bluetooth Headset. It should work but if it doesn't, check the Manufacture's Website for any support.
    I cant listen to music connecting my bluetooth
    check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
    or
    search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
    Phone can't pair with bluetooth but is bluetooth compatible.
    well whats the problem you cant connect your bluetooth to your phone or is it not comming up on your phone? did you pair it correctly?
    Hello
    yes you can connect bluetooth to iphone you go into your settings and register bluetooth
    bluetooth has to be on and charge while the phone searchs for bluetooth
    some bluetooth are compatible with i phone some are not
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    ZJ Limited
    ZJ Limited
    Steve Sweetleaf
    Steve Sweetleaf
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
