Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
Konmica minolta magicolor 2430 gives filter failed error
  • Konica Minolta Master
  • 6,850 Answers
Self Help Product Support Konica Minolta Business Solutions Inc
try this site for help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 25, 2016
SOURCE:
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
  • 44 Answers
SOURCE: konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: Printer leaves two white lines when it prints.
I had a similar problem with my 2430DL only with one fairly prominent white line instead of two. I read troubleshooting tips in manual for this problem and first suggestion was to wipe laser lens clean with a soft cloth. I did this and no more white line! If you do not have your manual please email me and I can forward you PDF manual. syberspirit@yahoo.com
Posted on Nov 23, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
  • 526 Answers
SOURCE: My printer is printing a duplicate image along
The most common issues for duplicate image is either
the drum or fuser. If you are able to measure the distance between the first line and its duplicate, i might be able to narrow it down.
thanks
Posted on Jun 02, 2010
Testimonial: "Thank you for the fast response. Very helpful."
I have a Magicolor 2430 DL which has worked great for the last few years that I have had it. But now it has a vertical white line through all of my documents and pictures. What can be causing this?
Hello
This issue is caused by the drum starting to fail. the Drum is what transfers the Toner to the paper and when it fails will cause streaking, lines and fading issues.
I hope this helps Regards GM
May 28, 2011 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430DLshowing Fatal o8h
Apr 18, 2009 | Konica Minolta magicolor 2430 DL Laser...
Minolta Magicolor 2430 DL
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
Sep 14, 2008 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
66 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
