When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
No, you have done nothing wrong. The D60 does not have the preview function on the monitor like the compact digital cameras. Nikon gave that function a name. It is called 'Live View'. The newr models like the D90 do have that feature. You can read further about your D60 here: www.digitalcamera-hq.com
You're reviewing the picture on the back of the camera, right? You're seeing the blown-out highlights. Those are the areas where you've lost all details. That's not always wrong, it depends on what you're doing.
If you don't want to see them, press up/down on the multiselector to see different views of the picture.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
When you are in the playback mode, press the up or down arrow on the back dial until the screen scrolls through the various overlays until you get to the screen you want...usually the screen with the frame numbers on it. If this helps, please rate accordingly, thanks.
reset your camera to factory settings. that will do.but if you dont want to lose all the settings then you should scroll the options in the menu bar and you should turn it off. thanks for using fixya!. please dont forget to rate my solution.
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
thank you-I appriciate it
