I recently purchased the Onkyo TX-SR605. This is my first experience with home theater. I have a 32" Akai lcd flat-screen. I have an HDMI cable connecting the receiver to TV. This is the only cable I want to run to the TV from the receiver. DVDs work fine. However, I don't know how to connect the coaxial cable to the receiver. There is no input for it on the back of the receiver. Previously, I just screwed the cable into the TV (I don't have digital cable; just regular). Do I need some kind of converter box? If so, can you recommend one? Also, I'd like to install an HD antenna to pick up HD signals over the air. I have the same question on this kind of connection to the receiver. Is there a box that will accept both the regular cable, and the HD antenna cable, and convert it to another type of connector that will fit the receiver? Sorry if this question seems basic; I've never done this!
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
I have the same question on the coaxial connection as well.
saem
Same problem. Is there no way to use some sort of adapter to serve as the middleman between the basic cable coaxial to the receiver??
Receiver went deaf after a static surge on the antenna line, only strong signals heard, noise floor dogie not increase when antenna connected.
