Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
A
Anonymous Posted on Jan 17, 2014
Change timer to stopwatch - Casio Sea-Pathfinder SPF40-1V Wrist Watch
Tag heuer stopwatch
Pull out the middle dialer once then try if that's doesn't work pull it again one will be the chronograph the other will be the stopwatch and if you turn the middle dialer it will change your clock
Apr 27, 2013 • Watches
tip
How to set your Global Atomic G-Force digital watch
This watch says "Strong Ideas" on the back instead of a 4 digit number.
Press LIGHT briefly and your LCD will be back lit for 5 seconds.
Press MODE to cycle through normal, alarm, dual time, and stopwatch display mode.
Hold MODE for 3 seconds to enable the radio to receive time signals. Once RC is activated, the watch will search for time signal automatically every day.
Hold LIGHT for 8 seconds to disable the RC function.
Press MODE, SET, and ADJUST simultaneously to reset the watch.
Press ADJUST while in normal mode to toggle year/time display.
Press SET while in year display to alternate Month-Day or Day-Month.
Hold SET for 2 seconds while in normal mode to cycle through world atomic radios (US/GB/DE/JP) push ADJUST to change, and SET to continue. Next the language will flash (GB/FR/DE/ES/IT). Next is DST on/off. Next, in order are hour, minute, second, year, month, day, and 12/24 Hr format.
(US only) Press SET to display timezone. The default is PA, use the ADJUST button to cycle through MO, CE, or EA as desired.
Press SET while in alarm mode to toggle alarm on/off.
Hold SET for 2 seconds while in alarm mode to change the hour and minute with the ADJUST button.
Press SET for 2 seconds while in dual time mode and ADJUST +/- 23 hours from normal time.
Press MODE to exit most settings.
Press ADJUST in stopwatch mode to start/stop the timer accumulatively.
Press SET to reset stopwatch to zero, or split measurements if timer is running.
Change the battery with a new CR2025 to prevent damage that low or dead batteries can cause by leaking.
Do not use solvents to clean the watch, use only a dry or water moistened cloth.
Do not use buttons when the watch is wet. Water may penetrate the watch and cause damage to it.
on Dec 31, 2011 • Watches
41helpful
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 • Watches
What are the little people you see moving at the top of the watch
it is probably that the stopwatch or the timer is turned on. press the mode button and check the stopwatch.
Aug 13, 2011 • Watches
How i can change analog time
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
8helpful
Manual for ultrak 340 sports timer
Here is a link to pdf maual file. This should help.
www.cei-ultrak.com/sport-stopwatch/pdf/340.pdf
6helpful
Watch settings
Press MODE and it jumps to Timer. Press mode again and jumps to ALARM set. press MODE quickly and jumps to time set. press START/STOP to reset and press RESET to change to minutes or hours. press RESET again and changes to Date Set...
Sep 17, 2008 • Watches
3helpful
2answers
Resetting stopwatch dials - Armani AR5331
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
