Question about Nor-Lake Refrigerators
The temp char recorder is not working
We have a norlake nspr522 and the temperature chart recorder is not working how can i do?
    Guru:
  • 462 Answers
There are a few companys that make temp chart recorders that are battery controled and you could get one of these and just put it inside the refrigerator, problem solved. Check at United Refrigeration, and Johnstone Supply they both have manufacturers that will allow you to keep charts. The 2 things to keep in mind 1 How often are you going to change charts, 2 what temperature range are you looking for.
Oh yes and Im sure there is a company that makes a remote sensed temp recorder that can tie into a computer and print out charts as needed. This is a little more specialized but I know the technology is asvailable. Probably Johnson or Penn Controls would know about this.
If this helps you in any way please rate me as high as you can. If you need to contact me and I can do the searching for you post back.
Posted on May 29, 2009
SOURCE:
How can I adjust the temp. on a norlake walk in cooler?
There are many variations for a Norlake system
I assume the cooling coil hangs from the ceiling of the cooler and the condensing unit sits on the top?
The temperature is controlled by a control that is located in the condensing unit on the top of the cooler. This can be either;
\ a digital thermostat. You will need the progam key to get in
\mechanical thermostat. Adjust the dial setting
\ pressure stat. Adjust the dial setting
Probably best to get a technician in
Apr 22, 2011 | Refrigerators
I recently have a new trany and water pump in stalled and now my temperature gauge does not work. How can I check it myself. Thank u very much for ur time.
Coolant Temperature Sender TESTING a coolant temperature sensor: Using an ohmmeter, measure the resistance between the terminals. Refer to the appropriate chart for your engine. If the resistance is not as specified, replace the sender. Fig. 1: Coolant temperature sender chart — gasoline engines 89552g87.gif
Fig. 2: Coolant temperature sensor chart — deisel engines 89552g89.gif
Fig. 3: Inspecting the coolant temperature sender for resistance 89552g90.gif
Jul 03, 2010 | 1990 Toyota Camry
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Norlake 6x6 freezer compressor
No probably just frozen up due to door being left open turn unit off and check internal unit have a look on the evaporator (internal unit) see if it has a covering of ice if so leave of utill completly frost free and then restart I bet it will work
Sep 09, 2009 | Refrigerators
I have a 6x6 norlake walk in freezer. The door remained open for 6-7 hours by mistake and now temperature does not go below 15 degrees. The technician told me to replace compressor as slowly temperature...
I've worked on freezers for over 20 years and have never heard of a compressor going bad because the door was left open. think about a second opinion.
Also, has the cooling coil inside the box developed and frost or ice build up? If so, it needs to be completely defrosted. If you defrost it manually, use a hose hooked up to hot water. Kill all power and hose all build up off. Remove the sheet metal housing ends and be sure there is no ice inside there too. I would go in this direction first.
IN order to kill a compressor under this condition, something really strange must have happened as anything is possible in a refrigeration system. Good luck and hope this helps.
Sep 06, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
I would like to know the standard temperature for a freezer
The factory presets your temperatures to the MID / MID setting of 0ºF for the freezer.
Apr 22, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Dec 05, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Refrigerators Logo
103 people viewed this question
Top Nor-Lake Refrigerators Experts
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
