Nostalgia Electrics Helman Group CCP-510 Circus Cart Popcorn Maker Logo
A
Anonymous Posted on Jan 16, 2014
Ccp610 light bulb - Nostalgia Electrics Helman Group CCP-510 Circus Cart Popcorn Maker
Need to know where to buy a light bulb 120 volt 820 watt
There is no such light bulb, I assume that is a typo.
Bring your old light bulb to the hardware store with you, they will have one that matches. The lights are just standard lights, not heat lamps.
2helpful
What bulb is the turn signal bulb on a 2002 oldsmobile alero
On 2002 Oldsmobile Alero Car Light Bulb Size, check this list:
Low Beam Headlight Bulb Size: 9006 or 9006 HID Upgrade KitHigh Beam Headlight Bulb Size: 9005 or 9005 HID Upgrade KitParking Light Bulb Size: 3157NALLFront Turn Signal Light Bulb Size: 3157NALLRear Turn Signal Light Bulb Size: 3157LLTail Light Bulb Size: 3157LLStop Light Bulb Size: 3157LLHigh Mount Stop Light Bulb Size: 921Fog/Driving Light Bulb Size: 894License Plate Light Bulb Size: 194Back Up Light Bulb Size: 921Front Side Marker Light Bulb Size: 194Rear Side Marker Light Bulb Size: 2825Glove Box Light Bulb Size: 194Map Light Bulb Size: 212-2Dome Light Bulb Size: 212-2 or 561Step/Courtesy Light Bulb Size: 168 or 73Trunk/Cargo Area Light Bulb Size: 211-2
Hope helps.
How do replace driver side headlight bulb? What size do I get?
Go to your local auto parts store.Ask at the counter,give them your make and model and year.
High & Low Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 194NA
Front Turn Signal Light Bulb Size: 7507 Or 2827
Rear Turn Signal Light Bulb Size: 7507
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 7506
License Plate Light Bulb Size: 168
Front Side Marker Light Bulb Size: 194NA
Rear Sidemarker Light Bulb Size: 7443
Dome Light Bulb Size: DE3175
Trunk/Cargo Area Light Bulb Size: DE3022
The bulb is in a socket which will twist out,then there may be a clip that holds the bulb in.
Drivers side brake light and horn won't work,,is it the multi function switch? 1999 chev blazer 4x4 . if so how much does a new one cost?
No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
High Beam Headlamp Light Bulb Size: 9005
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
1helpful
2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
Ash Tray Light Bulb Size: 558
Dome Light Bulb Size: 562
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
2helpful
2answers
What lamps takes ford focus 2001
This may help
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 3157LL
Front Turn Signal Light Bulb Size: 3157LL
High Mount Stop Light Bulb Size: 2825
Fog/Driving Light Bulb Size: 899
License Plate Light Bulb Size: 6418
Back Up Light Bulb Size: 3156LL
Map Light Bulb Size: 3886X
Dome Light Bulb Size: 6411
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
1helpful
I have a 2000 Mountaineer. The front parking lamps are missing along with the bulbs. Does anyone know what exact bulb is needed to replace these? Many thanks
2000 Mercury Mountaineer Auto Light Bulb Size Guide
High Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 3157NALL or 3457ALL
Front Turn Signal Light Bulb Size: 3157NALL or 3457ALL
Rear Turn Signal Light Bulb Size: 3156LL
High Mount Stop Light Bulb Size: 922
Fog/Driving Light Bulb Size: 9006
Front Side Marker Light Bulb Size: 916NA
Ash Tray Light Bulb Size: 161 or 194
Step/Courtesy Light Bulb Size: 168 or 906 or 912
Trunk/Cargo Area Light Bulb Size: 211-2 or 562
Under Hood Light Bulb Size: 906
Instrument-General Light Bulb Size: 194
Check Engine Indicator Light Bulb Size: 194
Hi-Beam Indicator Light Bulb Size: 194
Seat Belt Indicator Light Bulb Size: 194
Brake Warning Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: 194
6helpful
My license plate lights are out...what kind of bulbs do i need??
Check this reference guide...
2002 Hyundai Accent Car Lightbulb Size Guide
Parking Light Bulb Size: 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 2357A
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
From Sylvania Lamp Replacement Guide
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp.
I hope help you with this. Good luck (remember rated this help).
2helpful
How to replace headlight on a 2003 Chevy Tracker
There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
Here follows
2003 Chevrolet Tracker Light Bulb Size Chart
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 921
High Mount Stop Light Bulb Size: 168 Or 921
Ash Tray Light Bulb Size: 74
Trunk/Cargo Area Light Bulb Size: 168
Instrument-General Light Bulb Size: 158 or 74
Check Engine Indicator Light Bulb Size: 74
Hi-Beam Indicator Light Bulb Size: 74
Seat Belt Indicator Light Bulb Size: 74
Brake Warning Light Bulb Size: 74
Automatic Transmission Indicator Light Bulb Size: 74
Directional Signal Indicator Light Bulb Size: 74
Top Nostalgia Electrics Kitchen Appliances - Others Experts
john h
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
