Repair Clinichttps://www.repairclinic.com > RepairHelp > Electrolu...
Here are the most common reasons your Electrolux washing machine is leaking water - and the parts & instructions to fix the problem yourself.
.. Slip a sheet of newspaper under the bottom of the machine and it will indicate the area. If is does it when the machine is not running. My guess is that it is around the pump because some water always sits there, so either the pump body or the drain hose itself.
? 3:55 www.youtube.com/watch?v=3D5q1ynWb-U Jul 28, 2012 - Uploaded by SamuraiRepairman
... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Could be heater leaking, especially if it smells like antifreeze.
Also could be front windshield seal leaking. Or some seal
on the engine side of the fire wall leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it. If leaking behind unit : check water hose , is it placed properly ? If leaking under unit : call technician to repair it. good luck.
first check where it's leaking from, if water dropping near front wheel it's leaking from tank first check the rubber grommet for both washer motor 1 wiper washer motor and 2 head light washer motor, both are in the water tank, if your car water dropping from front end under the front bumper it should leaking from washer nozzle in this case need to replace the head light washer nozzle. some time leaking from hose if you check from underneath you can see where it's leaking from,
TRANSMISSION LEAKS COME FROM TRANSMISSION OIL PAN GASKET LEAKING.OIL COOLERS LINES LEAKING.LEAKING AT TORQUE CONVERTER FRONT SEAL.TRANSMISSION SPEED SENSOR SEAL LEAKING.FRONT AXLE SEALS LEAKING AND LEAKING AT TRANSMISSION COOLING LINES TO RADIATOR.CHECK ALL YOU WILL FIND LEAK.IF YOU HAVE FAST LEAK OR PRESSURE LEAK.WITH CAR RUNNING IN PARK EMERGENCY BRAKE APPLIED LOOK UNDER CAR IF YOU SEE FLUID LEAKING OUT IN LARGE QUANITIES.COOLER LINES LEAKING OR TORQUE CONVERTER FRONT SEAL LEAKING.IF YOU HAVE SLOW LEAK THE LEAKS HAS TO BE AXLES SEALS OR PAN GASKET LEAKING OR VSS SENSOR SEAL LEAKING.
this is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
