Reset to factory settings. S4 acctive . Missing the mc icon . I was to D this be the best way . How do I do this without lsing my data stored on gmail g acct
The easiest way to perform a Factory Reset on your Samsung Galaxy S4 is from within the menu settings:
Settings > Accounts > Back Up and Reset > Factory Data Reset > Reset Device > Delete All/Erase Everything.
Please remember to back up any data you want to keep first! In the Factory reset screen you also have the option to Backup My Data and Auto Restore. These are good options to tick before you Factory Reset if you're not too sure how to do this on your own.
If you're at all paranoid about your SIM card or SD card contents just take them out before you do the Factory Reset. Attention: if you reset your device to the factory default with SD card encryption setting enabled, the device will not be able to read your encrypted files. Disable this setting before resetting the device.
Alternatively, you can type in *2767*3855# on the key pad and that will do the same thing.
Remember sometimes you don't need to go even this far to solve problems. First of all try just turning your phone off for a while, or removing the battery entirely. Sometimes something as simple as that is enough to clear up some simple problems.
But if you've tried all of these methods and are still having problems, you can try a Hard Reset, the instructions for which are here.
SOURCE: Samsung SCH-U740 Master Reset
Let me elaborate. On your phone press the:
1. Menu--scroll to Tools & Settings---press OK
2. Look for Security, press OK
3. Enter the last 4 digits of your phone #, or whatever you set the lock code to.
4. There should be an option to delete contacts. Becareful not to press the Reset Default option, for it will erase everything (ringtones, pix, filx, screensavers, etc..)
**If the Security option is not seen in the Tools and Settings, then choose Call Settings or Phone Settings. It should be in one of these.
SOURCE: factory reset
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*7673# = Sleep mode RESET
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
*2767*73738927# = WAP Settings Reset
Try at your own risk .. i can't guarantee !!!
SOURCE: Sony Ericsson K850i Reset to back to factory setting
I'd imagine that you can look through the modes, or have a master reset, Master reset located Options. Then i think it's the one right at the bottom. I think. Hope this has helped.
SOURCE: samsung tocco limited service
re limited service not able to make or recieve calls
re flash phone firmware use multi downloader and usb cable that came wuth phone you will need to download flash files u can find out how to flash phone on net i had same problem it worked for me
SOURCE: reset s3310 to factory default settings
*2767*3855# is the master reset code and "if" it asks for password type *#9072641*# ..
if it works or not works mail me at [email protected]..
therefore i can work with more..
i hope,it solves your problem..
"rate solution"
