I also have the same problem with the LCD not being on when the camera is in operation.
Once the LCD is in its closed position, the view vinder activates, and all the appropiate touch screen buttons still function, but the LCD is not one.
Please help me with this. my camera is a Sony Handycam DCR-DC42E I also have the same problem with the LCD not being on when the camera is in operation.
AnonymousFeb 08, 2008
LCDSCREEN BLANK .CANNOT BRING UP MENULCDSCREEN BLANK .CANNOT BRING UP MENU
I have the same problem. all function it fine, except the LCD no display, it's everything black. the touch screen it's ok too.
what can i do?I have the same problem. all function it fine, except the LCD no display, it's everything black. the touch screen it's ok too.
what can i do?
I have exactly the same problem. LCD is black but otherwise the camera functions fine. The buttons on the LCD work (if only I could see them). Records and plays fine through the normal viewfinder.I have exactly the same problem. LCD is black but otherwise the camera functions fine. The buttons on the LCD work (if only I could see them). Records and plays fine through the normal viewfinder.
I have the same problem. LCD screen is black can only use viewfinder mode. My camara is just 15months old.I have the same problem. LCD screen is black can only use viewfinder mode. My camara is just 15months old.
I too have the same problem as ramesh, could any please let us know the solution if any.
Thanks,
vinodI too have the same problem as ramesh, could any please let us know the solution if any.
Thanks,
vinod
AnonymousMay 11, 2008
I have the same problem, suddenly the LCD screen stop working, please tell me how to fix the problem.I have the same problem, suddenly the LCD screen stop working, please tell me how to fix the problem.
AnonymousMay 20, 2008
no display in camcoder LCDno display in camcoder LCD
I have similar problem, the LCD first went dim and then dissapeared totally, I have similar problem, the LCD first went dim and then dissapeared totally,
Hi i had the same problem and i got it for the second time. can i please know how to remove the camera so i can replace the strip my self. And do u have a service manual. if so can i know where to get one for my self. thanks
the flex wire of the lcd monitor is already cut and already left is on
the touch screen that why is functioning ...go the sony service for the
replacing flex wire...or to the other service center for fixing the
flex wire....
CCD sensor seems faulty . Sony should repair free of charge but otherwise it is not an expensive repair to perform : requires 1 hour labout at most. ( the componenet itself is not expensive ).
the problem of your camera is the flexwire cable of the lcd monitor that why you don't see nothing in the panel,Also the message 'cover is not open' appears,while the cover is already opened the switch on cover have poor contact..it is not covered by sony service...it have to replace or repair that switch and flexwire cable....
I had purchased SONY DCR HC 42 in july 2005.
now i am facing a problem with the LCD display. whenever i open LCD screen nothing comes on it. view finder is working fine.
kindly help me out
Pritu
what can i do?
mine is the same.
Mine is the same problem as everyone esle. LCD blank - everything else is fine can still use the menu but cant see the icons.
Any suggestions ????
Thanks,
vinod
SAME PROBLEM FOR ME. LCD SCREEN IS BLANK. PLS HELP
I have exactly the same problem and I have detected thaat the flex is broken. Where can I get these flex?
