Battery not detected??? how to fix
SOURCE: new acer extensa battery price
try this link
http://www.batteryuniverse.com/Laptops/Acer/Extensa-4620/CONIS71_Acer_Extensa_4620_Laptop_Battery
SOURCE: dont know how to turn on my web cam on an acer
Try Start > All Programs > Your webcam's name.
Or, Start > Control Panel > Printers and Other Hardware > Scanners and Cameras > Webcam.
afraid you have broken the laptop screen its easilly done, they are straight forward to replace but prices are usually about 45 pounds on ebay for that model, you will have fitting on top unless fitting yourself though, if you are fitting it yourself all you need to do is remove the 4 screws from each corner of the screen and gentle remove the plastic facing around the screen, then remove the 2 screws from each side of the screen then disconnect the cable, put in new one attach cable and seal the laptop back up and that will fix your problem.
SOURCE: I have an acer extensa 5635 with a full battery that wont turn on.
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
