In my Nokia 6300 when I try to save the gprs settings it says "only 70 sets allowed, settings discarded" !!!
If I try to input the settings manually it says " memory full, cannot add new account"
How can I get the gprs settings saved in my phone?
Cannot get GPRS setting at my Nokia 6300
Hi thanks for using fixya!!!
I suggest that you restore your Nokia 6300 to its factory default, then contact your service provider to send you over the air the GPRS settings and configurations or you may go to their office.
If you need further assistance, let me know!
SOURCE: IN NOKIA 6300 GPRS SETTING NOT SAVE DISPLAY SHOWS ONLY 70 SET ALL
Follow the following steps to save your configuration settings.
1: Download & install OxyCube.
2: Connect your phone with USB cable. (USB Cable drivers must be installed)
3: Run OxyCube.
4: Select C: (Your phone memory).
5: In folders tree select Omadm Folder.
6: There will be 70 Numbered folders under Omadm.
7: Delete all folders accept first 5 & the folder named PRECFG.
8: Disconnect your phone.
9: Reboot your phone.
10: Either request you provider to send you settings. or insert it manually.
11: This time the settings will save normally.
Waiting for your positive comments.
SOURCE: setting discarded
Dear sir
please i wanted to configure gprs on my nokia 5200 but i cant whenever i enter in to configuration setting the phone will show not enogh memory
ineed your help
SOURCE: In my Nokia 6300 when I try to save the gprs
Check this site. This is my blog where i have posted the solution for this error. I found it for my nokia 6085 and worked well. Check it: http://inxis.blogspot.com/2009/11/gprs-mms-settings-error-nokia-solved.html
My solution is required another nokia 6300 that no this problem and need program NOKIA PC SUITE.
first you should backup setting from this phone via nokia pc suite
after connect your phone 6300 that have config problem to computer
then restore the setting from backup to your phone after restart your phone and enjoy.
SOURCE: nokia6300 gprs settings problem
Check my blog. I have found and written the real solution for this error. http://inxis.blogspot.com/2009/11/gprs-mms-settings-error-nokia-solved.html
thanks for the immediate response.
I have already tried restoring it to the factory defaults and even flashing the phone, still the problem persists.
Wht could be wrong ???
