When Magic Jack Plus inserted into USB port it is working. How I can replace power supply for Magic Jack Plus?
SOURCE: Flashing power button - no keyboard nor mouse. But PC works... ??
Yes, it may be that the +5v supply from the PSU is faulty, as the PS/2 ports run on 5v and USB runs on 9-12v. Replace the PSU with another of the same form factor and same power rating or better (>=230W). They come at ~£30, so not too expensive. For a little more. Try this:
http://www.quietpc.com/gb-en-gbp/products/psus-300-500/x-red-psus
SOURCE: Power went out when plugging into usb port, cant get it restarted
try getting an internal USB 2.0 PCI card.. that should work.. the front USB ports are not adequate you can buy one here.
SOURCE: usb ports not working, drivers ok,
Dear Greg.
If you recently or earlier installed any type of Audio or Video Hardware such as an Upgrade. or better equipment than originally come with your Computer, than the New Equipment Nullifys your front USB. You probably have to go to the rear of your computer instead of using the convienient front. If that works than you have to decide is the new equipment worth the inconvienience. Hope this helps,
please rate my service even if its bad, thank you.
also, another tip is to use Fire Fox, thats a Free Bee if you own a portable SanDisk which stores info like a disk. which is probably why you want your USB instead of just Cameras, External Plug Ins, ETC.
SOURCE: Year old desktop usb ports went dead. Are powered
If multiple USB ports don't work at the same time, the problem could be the USB device you are using or the USB controller. If the controler, go into Device Manager and see if any problems (? marks). If no problems, right-click on the USB Controller and update the driver. If ? mark, contact FixYa again for further help. Good luck.
SOURCE: I PAID FOR MY MAGIC
Contact the "Geek Squad" guys at a local Best Buy store. They're Best Buys' electronics go to guys. They'll help you out w/MJ
