I didn't use the camera for a long period of time (maybe 6-7 month). After I turn on the camera I saw that everything is ok, but I can't take pictures with it. I can change the setings, navigate through the menus, when I press shutter-release button half-down, the focus works fine, but if I press the shutter-release full-down(to the bottom) to take the pictures nothing happens. I cannot capture the picture. I tried different workarounds but without success: - recharge and replace the battery - replace the memory card - reset camera to default setings - try to use self-timer (2sec or 10sec) - try to recording video, but no chance
The manual only can give two reasons why the camera would not take pictures.
One, there is no memory card placed.
Two, the memory card is full.
You are sure you have placed a working empty memory card.
If you did save all the pictures on the memory card to a computer, try formatting the card in the camera.
When you are pressing the shutter release button half, does the camera say it is focused correct? light bottom corner of the display.
Your camera has a setting to take pictures with a remote control. Did you put the camera in that setting? Read page 76 of the manual.
success
Testimonial: "Thanks for the suggestions, but no improve. The memory card should be excluded, I have 2 and I format the card with camera, with pc and are empty. When I press shutter release button half, the camera indicate that focus is correct. I tried also with the remote control, it's not the original but compatible with KM A200."
SOURCE: camera wont take pictures
Contact the Tech Support site if the manual does not cover the problem.
SOURCE: I'm having trouble getting the self timer to work
Have you actually set the camera to take self-timer pictures or are you just pressing the shutter half-way to focus and then all the way?
