How to work on Scotsman Prodigy Ice Machine
MAKE SURE UNIT IS LEVELED TO START OFF, SOMETIME THESE UNITS LEAK FROM THE FOAM IN BETWEEN THE EVAP WALL AND SUMP YOU CAN ADD SILICONE TO THE OUT OUTSIDE TO HELP STOP THIS LEAK(NEEDS TO DRY AND CLEAN SURFACE) BY THE CONDENSER, THE AIR FILTER NEEDS TO CLEAN OFTEN TO PREVENT WATER VAPOR BEING SUCKED IN FROM WATER SUMP OR BIN... WHERE IT LEAKING FROM IS VERY IMPORTANT INFO TO KNOW
I need to know where the water is leaking from is it running over the sump tray? and when dose it leak? during freeze cycle or harvest cycle? Check the water fill valve to make sure it is not letting water through the valve during freeze cycle, also check dump valve during harvest cycle to make sure it is opening to empty sump tray.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? where is the water leaking from?
